kamejoko80
Member level 3
spartan-2 configuration problem
I used the Xilinx paralel III to configure the spartan II XC2S50 by iMPACT webpack ISE v6.3
I selected boundary scan mode TDI, TDO,TMS,TCK
The iMPACT auto identified XC2S50 successfully
The problems are :
My FPGA's ID code is different from the Xilinx's FPGA ID code
I don't understand this warning : "iMPACT:1049 start up clock has been changed to JtagClk in the bitstream stored in memory, but the original bitstream file remains unchanged"
After downloading .bit file the error message appeared:
checking pin Done
'1': program terminated , Done did not go high
and the status is "Programming failed"
help me,Pls!
The problems are :
checking pin Done
help me,Pls!
