Spartan 3e multiboot
veeru.jkm
Newbie level 1
Newbie level 1
I am trying to implement multibooting using spartan 3e 1600(Using ISE 13.1)... but as i am new to the field i don't know exactly how to use Primitive "STARTUP_SPARTAN3E" please suggest if there is any reference design is available.
I have done some coding as per my understanding. I could create mcs file which contains
multiboot trigger bit stream for BPI UP mode and non multiboot trigger bit stream BPI Down mode but when load into fpga
it's not working even done led not glowing.
I am uploading my design files(multiboot trigger files for BPI UP mode) please look into them.
Thanks and Regards,
Veerendranth
PFAs regarding above post...
  • blink_led.txt
  • multiboot_module.txt
Try looking at XAPP468 which discusses fail-safe configuration (multi-boot). That might give you a starting point.
XAPP468
