Sound Recognition using Neural Networks
memon
Newbie level 2
hi every1,
I want to Recognize different kind of sounds using neural networks in matlab ... can any1 help me out in implementing dis plzzz....
Is it that you want to recognize a human voice?....In any case neural network has to be trained with sounds from various sources (training data) and the classify the sounds from different sources based on the training data accordingly. This is how you have to perceive your project. Specific doubts will be easier to solve.
Reactions: memon
    memon
Basically i have to recognise different kind of sounds i.e. door bell,mobile phone,ringing alarm etc using neural networks.
i want to implement this in matlab .... can u help me in implementing this??
MATLAB is easy to use for Neural Networks.
But first you have to define the number of neurons and no of layers you want to use.
these are simple equation which update its weights.
try to read about neural networks then explain your problem please.
my project topic "Speech recognition using neural network".
can any1 provide some documentation so that i can understand the topic very well.
I hav some doubt about the topic
1. what will be the no. of Input Nodes in the neural network? and what data it will contain
2. what will be the no. of Hidden nodes? and what data will it contain
3. Can a single layer replace the multiple layers on the neural network
3. Basic working of the network
4. what will be the voice features and how will be the training done in neural network
5. no. of bits it will operate on?
6. structure of the neural network used in the system
7. How many set of input values required?
need help plz reply
There are two methods.
1) Speaker dependent recognition
2)Speaker independent recognition.
I don't know anything about speaker independent but in speaker dependent you have to find take atleast 10 samples of a single word (say "one") and then you have to find the melcepstrum for each and you have to give this as input to the neural network. You can use the neural network toolbox. There is also another separate window for pattern recognition in matlab. You can use that too.
Note: If you don't get accurate results then you have to increase the number of samples for every single word (say "one", "two" etc). The accuracy will keep on improving as you keep on increasing the number of samples.
kk but what will be there on the the Hidden layer and Output layer of the neural network if m using multilayered Perceptrons?
Hi everyone
I am new to this forum. I am also working on the sound recognition on neural network in matlab. Can someone please help me with training the NN.
---------- Post added at 11:48 ---------- Previous post was at 11:47 ----------
Hi everyone
