Some VCO questions regarding amplitude
eric0825
Newbie level 6
Taiwan
Some VCO issues
Deal all:
I am a rookie of IC design engineer~I got some problems recently...
1.While design VCO, how to estimate the VCO amplitude? I know it is equal to the bias current multiply by the equivalent tank resistance with a efficiency factor~but here the problem in real design is how to estimate the tank resistance? coz the model provided by foundry of the passive element is not just a resistance in parallel with ideal inductance but more complicated~so how to calculate it or simulate by EDA tool?
2. I've study many papers about VCO, but i can't still understand what differential amplitude and single-end amplitude is, does it means the amplitude reference to another VCO output and reference to ground?
khouly
Advanced Member level 5
EGYPT
Some VCO issues
with eda tools , u can get the total equivalent resistance of the resonator "tank circuit" ,
or use the EDA directly to get the output power of the VCO "the amplitude"
the differential output is the voltage difference between the two output nodes , most of the VCO's now are fully diferential
about the single ended is the voltage of one of the outputs with reference to the ground
khouly
milkdragon
Member level 3
Re: Some VCO issues
To determine your tank impedance, the simpliest way is to put a ideal AC current source with magnitude of 1, do AC analysis then plot the voltage at that node, which is the impedance also
eric0825
Newbie level 6
Taiwan
Re: Some VCO issues
Thanks for ur help~
Take inductor for example, I usually use the EDA tool to get the S-parameter of the inductor, thus i can get the Y-parameter or Z-parameter, then I calculate the equivalent parallel conductance from the real part of Y-para and equivalent series resistance from real part of Z-para, by the same way, i can also get the equivalent series or parallel inductance from imaginary part of Z-para or Y-para (because of the limited Q-factor, the equivalent series inductance is not equal to parallel ones), i am not sure if this method is correct? Because as i know, the imaginary part of Z-para and Y-para is also contributed by f the parasitic conductance of the inductor, it may result in error of the calculated inductance value.
jecyhale
Advanced Member level 1
China
Re: Some VCO issues
eric0825 said:
Deal all:
1. you can calculate. but some time the simulated result is better.
and the phase noise is impacted by the amplitude.
2, differential is the double of singal-end.
