Some questions regarding pic microcontroller programming
mosfet12
Newbie level 5
While doing programming to use different registers,bank changing is necessary. Suppose to use a register i moved to bank 1 program and can i continue programming from bank1 till the changeover is necessary or i have to goback to bank o all the time to continue the programming.
As long as all the registers you're accessing at that point are in bank 1, you don't need to switch back to bank 0. Bank changing is necessary when you'll access a register which is not in the same bank as the one you're in.
Hope this helps.
Tahmid.
What Tahmid says is correct, however its perhaps better to switch back to bank 0 otherwise you may not realise you are still in bank 1.
Are you using the 'banksel TRISA ' directive rather than the bcf STATUS,RP0 etc ; its easier to use , just use banksel 0 to return to bank0
If you use the 18F chips all the system registers are in one bank and the user registers are in 256 byte banks so its so much easier to code.
