JackyH
Newbie level 6
Hello, I am not sure about some rules of the layout and I am wondering are there any reasons for these rules.
1, The ground plate should be as large as possible.
It is also better for the voltage supply plate as large as possible, therefore there is a very large overlap area between the ground plate and the voltage supply plate.
-----so the votage supply on the whole chip will be stable, the current are distributed on the whole chip?
2, It is better for the signal line not to overlap with the other signals, and it is also better to avoid the signal line to overlap with the power supply plate???
Could signal line overlap with the ground plate? ??
-----to reduce the coupling between the signal line and the power supply?
