PG1995
Full Member level 5
Hi
The following is the snap of a frequency generator or signal generator:
https://img21.imageshack.us/img21/4708/freqgenerator.jpg
At the top it says 0.2 hz - 2 mhz . One mark on the dial marks 0 .05 (0.05 x 4= 0. 2). On the dial this has markings right side also (in clockwise direction). There are 8 markings (starting from 0) on right side of 0.2 , does this mean every marking stand for 0. 025? As someone has told me that the value on dial is multiplied with the set frequency to get required frequency. If frequency set is 1 khz and I have 0.5 on dial , then resulting frequency will be 500 hz . Correct? But as you see there are markings smaller than 0.2, so it is possible to get frequency smaller than 0.2hz (1 hz x (any value on the dial smaller than 0.2). That means frequency generator can produce frequencies lower than 0.2 hz , then why does it say at the top that it can produce frequencies from 0.2 hz -2 mhz? Please tell me .
What is function of "Pulse Out " and "VCF"?
What is function of "DC OFFSET " and "SYMMETRY"?
What is function of "20dB " and "INV"?
I am much grateful for your help. Thanks.
