Some basic questions regarding the attached code
ipunished
Junior Member level 3
United Kingdom
Im learning Verilog by example from Chu's book..
so have a few basic questions..
this code is for a simple counter:
module  univ-bin-counter
#(parameter  N=8)
input  wire  clk,  reset,
input  wire  syn-clr  , load,  en, up,
input  wire  [N-1:O]  d,
output  wire  max-tick,  min-tick,
output  wire  [N-1:O]  q
//signal  declaration
reg  [N-1:O]  r-reg, r-next;
//  body
 //  register
always  @(posedge clk,  posedge  reset)
if  (reset)
r-reg  <=  0;  //
else
 r-reg  <=  r-next;
//  next-state  logic
always  @*
if  (syn-clr)
 r-next  =  0;
else  if  (load)
r-next  =  d;
else  if  (en &  up)
r-next  =  r-reg  +  1;
 else  if  (en &  -up)
r-next  =  r-reg  -  1;
else
r-next  =  r-reg;
//  output  logic
assign  q  =  r-reg;
assign  max-tick  =  (r-reg==2**N-1)  ?  1'b1  :  1'b0;
assign  min-tick  =  (r-reg==O)  ?  1'b1  :  1'b0;
endmodule
so basically.. what is this "next- state logic" ?? how many states are there?
cant i just write the code in one flow? why do I have to care about next state?
also in the next state logic it says
always @ *
so this means that at any signal change do whatever is in this always block... right?
so wont the clock also come in this? but we also have a separate always block above for always @ posedge clock and reset to do something else..
so for posedge clock wont both always be executed??
or is that what we want?
Im confused =/
Thank you
edit: please ignore the syntax errors in the code.. its not copying right from the poor quality pdf i have of the book
