isaacnewton
Full Member level 2
- Joined
- May 13, 2004
- Messages
- 143
- Helped
- 12
- Reputation
- 24
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Earth Village
- Activity points
- 1,134
(1) The attached is the Truth Talbe of a 4-bit ALU. I have a simple
question about it. Please look the circled expression: (A+B) plus AB
(Bar). What's the difference between '+' and 'plus'? Are they the
same? If they are same, why the author use different notations?
(2) The Logic Diagram of the ALU is also attached. From the figure,
we can see, the Carry in bit Cn and Carry out bit Cn+4 are
Active Low, and all the others are Active High.
What's the advantage of using some Active Low and some Active High
input/output?
(3) If I want to use TSMC 0.18 um
https://www.mosis.com/Technical/Testdata/tsmc-018-prm.html
to realize the ALU, how much of target Propogation Delay is
reasonable?
Thank you very much.
input/output?
reasonable?
