Solutions for converting serial port to USB
pasicr
Advanced Member level 1
Macedonia
I need info about conversion serial port to usb. Can anybody have some schematics or any idea?
regards
Serial to USB
look at my simple serial to USB with built-in windows drivers
hxxp://
Re: Serial to USB
Are you looking to build it as part of a project? If you just need a simple RS232 to USB adapter they can be found at many computer retailers for about $15
If you're starting from scratch pic an micro with built in USB.
Re: Serial to USB
Have a look on this website
www.ftdichip.com
I've used the FT232BM and FT254B in many designs and they work reliebly and very cheap.
PM me if u need any help.
Yours,
Serial to USB
I also use the FT2xxx chips and must say they are extremely easy to use and very flexible. Some of these devices can be used for serial as well as parallel applications. I think the Silabs versions are serial only (which is what you are looking for).
Victor
https://www.zerksus.com
Re: Serial to USB
Dear,
check **broken link removed** for usb <--> anything chips
good luck!
Re: Serial to USB
Hello
if u want to use an IC into u r board then it is better to go for FT245 which is PARLLEL TO USB, very easy interface,
and it requires no prior knowledge of USB.
I hope u get a USB DRIVER along with it,
Try this option
All the best
--Babesh
Re: Serial to USB
will this chips will work with Windows XP SP2 ?
Re: Serial to USB
Yes the FTDI chips has a Windows driver (On their site) (FT232/FT245) and the new FT232-R chips just requires a few extra components.
/Bingo
Re: Serial to USB
I use combined IC prog programmer for serial eeprom 24xx, 93xx with pic micro in 8, 18, 28 and 40 pin dip. I buy LAPTOP computer without serial port. I need this conversion (serial to usb) for this programmer,
regards
Re: Serial to USB
Check your programmer manufacturer for the recommended Serial <-> USB converter that will match your programmer as not all converters work correctly in this application. I had meny converters that did not work with my serial programmer and finally, i bought a USB programmer to get rid of all these problems...:cry:
Re: Serial to USB
:D FTDI is the best ,contact me my friend !
cyberwin technology ltd www.ftdichip.com
www.cyberwin.com.cn(chinese)
msn:yafan24517@hotmail.com
Re: Serial to USB
Bus Master said:
I've used the FT232BM ...
ft232R the best for new designs. No xtal no resistor no eprom required. All external parts included to chip :|
Re: Serial to USB
hi
i wond the pcb or chematic for the TUSB3410 board please
thank you
Re: Serial to USB
used a data cable usb for cellular phone o usb to rs232 adapter
