I've built a guitar amp using the schematics on this site **broken link removed**
It is mostly working fine, but when i flick the 'bright' switch, the opamp goes into oscillation. I've bypassed both power pins to ground with 0.1uF ceramics, and I've tried it with the power amp disconnected, so it's definetely got something to do with the opamp.
Could this be due to the lack of sheilding from the power supply? There is about 15cm between the preamp board and the PSU, but i haven't got any sheilding.
Also, when i turn both the volume, and master all the way down, there is a 'pop' then a quite hum. As soon as either of them is turned up again, there is a 'pop' then everything works fine.
Any Ideas?
Thanks a lot
Sam
