solar tracker using 8051
niranjan23
Member level 5
Member level 5
hello..
I want to do single axis solar tracker by using 8051 and with DC motor and LDR as sensor..I choose this project as my final year project...
can any one help for circuit diagram and assembly code for this
And I want three function in it
1st is solar tracking as usual (east to west)
2nd when panel move completely to west it gets back it's initial position (sun rises)
I have 10 RPM DC motor, 12V/10W solar Cell
Please help me for circuit and Assembly code .....
Use 2 LDR. conect both one side on the 5V and the other side on a 1K resistor to gnd.
The motor objective is to make both LDR voltages to the same level, case one os greater than other simply turn the motor and compare again.
This idea is simple and Works extremmly well, You can do without 8051 and only one opamp and a transistor, but also can be done by software on a microprocessor
I <<<< Piece off black plastic +- 10 cm long
I
I
I
I
___Ldr1___I __LDr2
thankyou ...very much ...it is very simple ...but if I want to do with 8051 ...what will be the assembly code...???
i want to use 3 ldr and is it necessary to send the signal through interrupt signal or generally through port1 we can send the signal
It is more easy with Ports... any ports..!! and program also easy.......dont go to interrupts
make one transistor circuit as show you previously and connect with port 1 pins....and make port programming...
my code goes like this bt i want ur help in this code and i need to complete it within 2 dys
while(0<count<=60|0<count1<=15)) //while tracking the sun to determine the position of stepper motor or moving fast to search the light
stepper_motor=1
while(60<count<=120|15<count1<=45)
stepper_motor=2
while(120<count<=180|45<count1<=60)
stepper_motor=3
while(p3=1) //when port 3 gets any signal ie when it get ldr get light
if(ldr1==1&&ldr2==0&&ldr3==0) //when signal came from 1st ldr
if (stepper_motor==1) //when motor is in the east postion
clockwise(); //rotate clockwise in a full 180
else if(stepper_motor==2) //when motor is in the middle position and ldr1 gets light
clockwise2(); //rotate clockwie from middle so only half rotation is required
else
clockwise3(); //rotate clockwise from west for little time only
T0delay(); //wait in west for sometime
anticlockwise();//move back to east fo the next day
T0delay(); //wait their for some time
rest(); //rest
if(ldr1==0&&ldr2==1&&ldr3==0) //when light falls on 2nd ldr
if(stepper_motor==1)
clock();
elseif(stepper_motor==2)
clock1();
else
clock2();
T0delay();
anticlockwise();
T0delay();
rest();
if(ldr1==0&&ldr2==0&&ldr3==1) //when light falls on 3rd ldr
if(stepper_motor==1);
clock();
else if(stepper_motor=2)
clock1();
else
clock2();
T0delay();
anticlockwise();
T0delay();
rest();
while(ldr1==0&&ldr2==0&&ldr3==1)
if(stepper_motor=1);
clock();
clock1();
else
clock2();
T0delay();
anticlockwise();
T0delay();
rest();
if(ldr1==1&&ldr2==1&&ldr3==0)//both ldr receives light
clock();
clock1();
else
clock2();
T0delay();
anticlockwise();
T0delay();
rest();
if(ldr==1&&ldr2==0&&ldr3==1)
clock();
clock1();
else
clock2();
T0delay();
anticlockwise();
T0delay();
rest();
if(ldr1==0&&ldr2==1&&ldr3==1)
clock();
clock1();
else
clock2();
T0delay();
anticlockwise();
delay();
rest();
if(ldr1==1&&ldr2==1&&ldr3==1)
clock();
clock1();
else
clock2();
T0delay();
anticlockwise();
T0delay();
rest();
} //WHILE1
}//MAIN
while(p3=0)//for no light search for the light by rotating left and right
if(ldr1==0&&ldr2==0&&ldr3==0)
for(i=1;i<4;i++) //for four times rotation continues
if(stepper_motor=1) //when stepper motor is in east position and no light falls
clockfast(); //rotate clockwise
elseif
stepper_motor=2
clockfast1(); //rotate half clockwise
else
stepper_motor=3
clockfast2(); //rotate little clockwise
T0delay1(); //wait for smtine in west position
anticlock(); //rotate anticlockwise
T0delay1(); //wait fir smtime
rest(); //rest position
clock() //function for clockwise rotation
P2=0X11;
T0delay(56);
P2=0X22;
T0delay(56);
P2=0X44;
T0delay(56);
P2=0X88;
T0delay(56);
anticlock() //function for clockwise
P2=0X88;
T0delay(75);
P2=0X44;
T0delay(75);
P2=0x22;
T0delay(75);
P2=0X11;
T0delay(75);
clock1(); //function for halg clockwise
for(count=1;count<=90;count++)
p2=0x11;
T0delay(56);
p2=0x22;
T0delay(56);
p2=0x44;
T0delay(56);
p2=0x88;
T0delay(56);
clock2(); //function for little clockwise
for(count=1;count<=45;count++)
p2=0x11;
T0delay(56);
p2=0x22;
T0delay(56);
p2=0x44;
T0delay(56);
p2=0x88;
T0delay(56);
rest() //at rest position
p2=0x00;
T0delay(56);
p2=0x00;
T0delay(56);
p2=0x00;
T0delay(56);
p2=0x00;
T0delay(56);
clockfast() //function for clockwise rotation
P2=0X11;
T0delay1(56);
P2=0X22;
T0delay1(56);
P2=0X44;
T0delay1(56);
P2=0X88;
T0delay1(56);
clockfast1(); //function for halg clockwise
for(count=1;count1<=45;count++)
p2=0x11;
T0delay1(56);
p2=0x22;
T0delay1(56);
p2=0x44;
T0delay1(56);
p2=0x88;
T0delay1(56);
clockfast2(); //function for little clockwise
for(count=1;count1<=15;count++)
p2=0x11;
T0delay1(56);
p2=0x22;
T0delay1(56);
p2=0x44;
T0delay1(56);
p2=0x88;
T0delay1(56);
//delay(unsigned int time) //delay function
//unsigned int i,j;
//for(i=0;i<time;i++)
//for(j=0;j<1275;j++)
void T0Delay() //delay by using timer
TMOD=0×01; // timer 0, mode 1
TL0=0×00; // load TL0
TH0=0×35; // load TH0
TR0=1; // turn on Timer0
while (TF0==0); // wait for TF0 to roll over
TR0=0; // turn off timer
TF0=0; // clear TF0
void T0Delay1() //delay by using timer
TF0=0; // clear TF0
