Solar Tracker Schematic, need help to design mechanical part
jami007
Full Member level 3
Pakistan
Here is a simple solar tracker, working fine, now I want to design mechanical part so need your help, I'm thinking to use Aluminum instead of iron and wood or steel.
below is the source link
here is a mechanical design, but I want to improve its design.
I also need some idea to reset solar panel initial position after sunset
Best Regards
  • Solar Tracker.zip
The design is good for higher latitudes. It will track the sun when it is low in the sky. Also when it rises and sets during cold season.
That looks like a counterweight at the back. Good idea. You can make that part out of steel of course.
Questions:
* Is the base supposed to be fastened to a roof? Does it allow access for you to clear away water, leaves, debris, wasp nests, etc.
* Is the center hold-down sturdy enough so the assembly will not tip over in high winds? For similar reasons is the assembly as short as possible?
* Are the wheels large enough that they can easily roll over leaf stems, twigs, etc.?
* Do you intend for the tracker to locate the sun automatically at sunrise (east horizon)?
* Do the curved rails permit sufficient travel of the assembly, so it can turn directly toward the east and west?
* Do the motors spin slowly enough to make tiny movements as the sun moves slowly across the sky?
* Can wiring be positioned to be clear of moving parts, yet without repeated sharp bending and causing wires to break?
* Will this design be able to follow the sun as it transitions through all 4 quadrants of the sky near zenith (as it can do if you are located within 23.5 degrees of the equator).
The up-down-left-right motion is an economical way to obtain alt-azimuth movement.
However the sun can be tracked over the entire day with just one motor. The axis of turning is around the polar axis.
Such a design would require a completely revised rack to support the solar panel.
The other motor will only need to turn on briefly every few weeks as the seasons change. It will tilt the panel higher or lower in the sky as the sun tracks a higher or lower arc in the sky.
Or the second motor can be omitted entirely, and the panel can be tilted manually at the change of seasons, four times a year (maybe as little as twice a year).
did you asked to answer these question??? or they are just for purpose of understanding
The design can work as is, above a certain latitude. Of the questions I brought up, at least a few will need to be addressed in certain real-life situations.
I did not have a tracker for my solar panels. I put them on the roof which was sloped down toward the south. I figured that was adequate for the time being, until I needed optimum performance if the grid were to go down longterm.
My panels got leaves and twigs on them. Wasps built nests underneath one or two of them.
Hey everybody, can someone post a single sided board layout of this tracker in Proteus, I'm not good in pcb design, so it will take much longer for me to design a pcb, if someone can help it will definately appriciated by everyone.
Best regards
Here is a PCB design of this Solar tracker, pdf and proteus original files attached
  • PCB design.zip
Reactions: paralk
    paralk
here are the pdf files for PCB
  • solar tracker bottom.PDF
  • solar tracker Layout.PDF
  • solar tracker bottom mirrored.PDF
