soc encounter - RC extraction questions
Sakr
Member level 2
Cairo, Egypt
rc extraction ict
I have few questions about RC extraction
What is the difference between hierarchical and flat wireload model? I've read about the difference in socUG, but I need a better explaination.
Is generating capacitance table important?
whoever if the ict file is not provided from the technology provider, who can you create one? from where do you get the required information, is LEF file contain this info.?
Thank you very much
~sakr
encounter create ict file
For accurate results we need cap table because basic cap table doesn't have all the cap values like fringe cap edge cap and so on.....
We can't create ICT file we can just convert ICT file to tch file or tch file to ict file there is one procedure.....
LEF contains but not much...
Reply me
BYe take care
    Sakr
encounter cap table
Thank you very much for your replay.
I have another question what is "tch" file? is this a standard file extension? I couldn't find it with the std. cells library files nor the PDK files.
However, what is the tools you use for this conversion?
Thank you very much
~sakr
rc encounter
tch file is a binary format and ict file is a ascii format....
