eda_wiz
Advanced Member level 2
Hi folks,
I get the below warning of partially routed nets in SoC Encounter. However verifyconnectivity check passes with 0 violations/warnings.
Is this something, I should be concerned about?:???:
#WARNING (NRDB-1005) Can not establish connection to PIN Q at (371.700 113.775) on MET1 for NET FE_PHN30_RST_N. The NET is considered partially routed.
#WARNING (NRDB-1005) Can not establish connection to PIN A at (363.300 113.750) on MET1 for NET RST_N. The NET is considered partially routed.
#47 routed nets are extracted.
# 2 (0.12%) extracted nets are partially routed.
Verify connectivity Log
******** End: VERIFY CONNECTIVITY ********
Verification Complete : 0 Viols. 0 Wrngs.
(CPU Time: 0:00:00.1 MEM: 0.000M)
Thanks
Thanks
