csotiriou
Newbie level 2
Hello everyone,
has anyone experienced the following error while running optDesign (IPO) in EDI-10.12?
<CMD> optDesign -preCTS
**DIAG[doFGMasterLoop.cpp:427:createMaster]: Assert "!theMaster_"
**ERROR: (ENCOPT-660): Could not run optDesign because of previous error.
**WARN: (PRL-38): Slave id 0 did not come up within the specified timeout period (30 seconds). Use setDistributeHost -timeout to change the value. This may be a real error due to incorrect or incomplete platform/machine specification provided via setDistributeHost to your distributed resource management system (LSF/Sun Grid Engine etc.). If running locally (setDistributeHost -local), the current machine may be overloaded with too many jobs and swapping (check free memory and CPUs with top). For local runs, consider reducing the number of CPUs you are using via the setMultiCpuUsage command or free up some memory by killing other memory intensive processes.
**ERROR: (PRL-5): Not all slave processes were able to start. Check that your distributed hosts are valid and restart Encounter.**ERROR: (PRL-0): Channel of slave 0 does not exist.
We have tried modifying the multi CPU options but the first error persists.
Any help would be appreciated.
Thanks,
Christos.
Thanks,
Christos.
