cupoftea
Advanced Member level 5
The attached is two 100W SMPS's in parallel. One (the master) regulates the output voltage, and the other (the slave) simply copies the output current of the master.
In the attached, the slave is obviously with a slower feedback loop than the master. Do you agree that this is indeed a requisite of this "master_slave" configuration?
PDF schem and LTspice sim attached
