smps schematic wanted!
mehdi_394
Newbie level 5
Iran
smps schematic
hi every one
I need a schematic for smps practical circuit with this parameters
Vac in:100v
Idc out=4A
Vdc out=12v
please , Help me if you can.I am in trouble for my final project and I don't Have enogh time to design this phase of project .
thanks a lot
smps project
A good place to find schematics is on IC manufacturers websites. Just search the web for an smps IC that will do what you need, then visit the website to get the data sheet. The data sheet will most probably have an example circuit and the manufacturer of the chip will most likely have some application notes on using the chip.
smps schema
mehdi_394 said:
hi every one
Vac in:100v
Idc out=4A
Vdc out=12v
thanks a lot
CHECK AT www.powerint.com
smps 12v 4a schematic
actually, to do it really simply......just get one of those powerint flybacks and do it with hysteretic control.....
If you dont want to wind a transformer, just use a buck converter, though the duty cycle will be low...unless its a tapped buck.
But a buck will do the job....
your ony prob then is the hi side switch.....you could use a bootstrap driver though to get round it..planty at IRF.COM
......or to be honest a pulse transformer isnt hard to set up for hi side drive.....
ot just go on the webbench on fairchils site, or is it natsemi ?
Powerint have some easy to compensate controllers...and a support website
...you can even buy there some of there transformers off the shelf
Added after 1 minutes:
oops by the way, "Laszlo Balogh" does a good hi side drive article for you to google to get..
anyway, if i may ask, what course are you doing ?
do they help you much, -
my lecturers used to talk at three hundred miles an hour and leave us all blank!
4a smps circuit
hi
you can check in the power int website,
it has multiple options of tiny switch or link switch and others, u have even the option of selecting the topology
one more thing for your info is it helps even in u r desing simultaions of the sch basing on the specifications given
bye
som
simple smps schematics
Hi , download a software PI Expert from powerintegration web site. You can design all types of powersupplies from that software. What you need to do is some fine tuning in the circuit. Thats it.
