sam781
Full Member level 4
I have been using a SMPS inverter for one years. Rating is as below -
Input voltage: 12V dc
Output voltage: 230V ac
Power: 500VA
I measured the output voltage before which was around 230-240v ac. All the loads were running properly. Suddenly, we noticed that Ceiling Fan moved slow than usual. I measured the output voltage ad 170-180v ac. Low output voltage is causing the low fan speed. I also measured the input battery voltage which is okay (around 13v DC). I cannot find the problem of this low output voltage. Where I can look in to resolve the problem? Any idea?
Power: 500VA
