tinska.h
Junior Member level 2
Hello,
I have never dealt with SMPS and I'm now planning to use a SMPS-module from TI (PTMA401120) to power my system which has noise sensitive areas. According to datasheet there is Vo ripple 85mVpp, and I have read that SMPS can cause some amount of ground noise.
I'm thinking about using LC-filter to filter out ripples and then use low noise linear voltage regulator. However, how should I deal with ground noise? I guess common chokes could be an answer? Or should I create a virtual ground for AGND(Or as I'm doing transimpedance amplifier, I could reference op-amps non-invert to virtual ground). I'm also using power rail to power my digital interfaces.
Which one would be better or what you would recommend? Any more neat solutions?
Thanks,
Thanks,
