leonardo0
Junior Member level 3
- Joined
- Aug 28, 2004
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 228
Hi to forum
I have 5 boards equipped with 8 channel adc and display .The board inputs i need to connect in parallel with each other
so signals can show wherever a board is located .In front of each input there are shunt resistors 10K working as selectable
pull up or pull down . The problem i have is that if a board power supply lines are not connected with the rest of boards leakage through input
shunt resistors destroy all indications .I dont want to use jumpers with diodes. Is there a very small simple circuit to isolate the inputs
when a board is not powered ?.Voltage range is 0..30 VDC
