SMD Soldering / Desoldering Tips Needed
johan_tr2000
Full Member level 1
Full Member level 1
smd tinning jelly
Hi All,
Can any one share the tips that I can do at home?
Thanks + Regards,
Tr2000
soldering desoldering smd
Hello,
For i used an ANTEX 17W soldering iron with 0,1mm pan. It's works well.
I test an another solution with hot air soldering and soldering paste (very expensive). For that I used a gas soldering with hot air buse from ANTEX.
The result feels good.
It's amateur solution but it's work
CD :)
Search according to quantity, variety of tips.
Not always is better pointedly tip. Somewhere in Elektroda is a link to GB site where was described SMD soldering technique.
If you solder SMD components with e.g. 0,5mm pitch is most better do not solder each pin separate but more pins at the same time by sideways moving of the plane (flat) tip. The pads must be tinned before.
1. tin plate the pads
2. solder outer pins to fix IC
3. apply liquid (jelly) flux
4. solder....
With this procedure we solder hundreds of TSOP 0,5mm packages with
a Diametral cheapest iron which costed about 60 USD (www.diametral.cz/english/e_index.html). This solder we use for everything...
We have Ersa and Weller irons too and we do not find any real differences between them. As Ersa as Weller costed about 190USD.
pool_77
tips for soldering and desoldering
see if tha attached pdf is helpful to you.....there are some tips for Soldering and Desoldering.
best regards :)
Hi WIilson,
Where is the attachement?
Regards,
Tr2000
johan_tr2000 said:
Hi WIilson,
Regards,
Tr2000
About lost attechments:
soldering technique
Here is the attachment......
i dont know what happened......i had attached the file ,but it got lost i dont know how....
any way i am again uploading it.....
regards
There are smd soldering sets for home users.Try to search in www.antex.com and google.They are not very expensive and works well.
Analyzer.
For soldering SMD u can soldering all pin with much solder paste and after
remove exceded solder paste with a desoldering pump.
Working right, with fine pitch too, but u need of a solder layer (usually green).
Sorry the attachment is for normal soldering, not SMT, though the tips are as useful.
For SMT, you can try fine-tip soldering. You sure need good amount of flux.
Hot-air does not work too well for me.
After that make sure you check for bridges. Suck them off by solder-wrick.
