rodv92
I am currently designing an antenna that exhibits a slight capacitative reactance (54 ohm -44j)
Since I have crude prototyping tools (a VNA and nothing more than the toner transfer method to make boards at home), I was researching a way to test and replace SMD components on the matching PCB on the fly
The matching network uses a differential output. I need to be able to replace two capacitors and one inductor.
I wondered if, by using vias with pins soldered into them, I could squeeze the SMD components between the two pins to test and reuse the board for other projects, (standard 50 ohm impedance and always the same f0 for all my projects)
I don't think homemade prototype board strips would suffer many soldering cycles before breaking down.
I would use rather big SMDs (2012 or 2520 metric)
Is it a viable option ? or does any fixtures exist to clip SMD components in ?
What is the standard approach ?
Any help appreciated.
