Small UWB Square Monopole Simulation Problem
talha.arshed
Newbie
Newbie level 1
I am trying to reproduce the result of the attached paper. It's a simple square monopole planar antenna. But somehow can't produce the result.
I am using 50 ohm waveport (10*w, 8*h). lamda/4 distance radiation box and substrate. delta s = 0.02. discrete sweep.
I have attached my Hfss file and pdf of research paper. plus results.
Waiting for replies
Regards
View attachment 2009-Small Square Monopole Antenna With Inverted T-Shaped Notch in the Ground Plane for UWB Appl.pdfView attachment 2009tshaped_waveguide.rar Capture2.JPGCapture.JPG
talha.arshed,
1. give 3.5*w and 4*h as the dimensions for the 50ohm port.
2. try giving a radiation box and check for the results.
