mikediamond45
I need a small, blue, flat LED with good wavelength coverage of 470nm.
I’m replicating an experiment which uses this LED:
NFSB036BT
Its hard to find, so I found a digikey alternative.
OVS5MBBCR4
https://dkc3.digikey.com/PDF/US2011/P2884.pdf
Can someone tell me if there is a major difference in the emitted light spectrum of both LEDS.
From what I can tell, the NFSB036BT may be better suited for 470nm, since it mentions 470nm on the first graph on page 11.
All I really care about is enough lumens at 470nm. Can the OVS5MBBCR4 deliver the same amount of lumens as the NFSB036BT at 470nm?
What do you think?
NFSB036BT
OVS5MBBCR4
What do you think?
