Plecto
Full Member level 5
- Joined
- Jan 4, 2012
- Messages
- 315
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 4,979
Hi. I'm having an issue with this class A headphone amplifier that I just made. It's powered from a 15-0-15V 30VA center tapped transformer and when I cut the power from the primary side of it, I get a pop sound in my headset. I know that this isn't caused by the voltage dropping, because my 4700uF capacitors keeps the amp operating for several seconds. I assume that the pop is caused by some spike in voltage from the transformer or something? I'm afraid I don't know transformers well enough to understand this I'm also having another weird issue when turning the amplifier on/off, it causes strange things to happen with other equipment around it. If I connect my headset to a different amplifier and then turn the first amplifier on/off, I hear a weak pop which have to be caused by something happening on the mains Also, my USB sound card starts acting strangely when turning my amp on/off (spotify has just downright stopped working a couple of times). I can't really begin to understand how my tiny amplifier can affect the mains this way so I would like some tips
