Smal size GSM and GPS modules - SMD
Stian
Norway
Smal size GSM and GPS.
Hi.
I am looking for a smal size GSM modem for smd mounting. Preferrably with integrated GPS module and good power specs. Though size is most important.
Anyone have any good suggestions.
I am currently using Telit GE865-QUAD. (22x22x3mm)
Anything out there that is smaller?
Thanks!
-Stian
Re: Smal size GSM and GPS.
Thanks for the link. The GSM module is a bit bigger then the Telit i have posted above. But the GPS was smaller then the one i currently use.
Thanks.
I got two G200's a few days ago and hoping to get them onto a demo board in the next day or so....
What kind of antenna's do you use on yours?
Dont really know what I will end up with yet. currently using a standard large GSM antenna...
Would like to use something like an Embbeded GSM Antenna ANT-GXE477a.
Dont really know. Haven't really looked in to it yet.
Any suggestions?
I do not have any suggestions and this antenna thing is new to me also as I previously used gsm modules which had sim card and antenna connectors on the module itself.
You seem to be serious about size :) The one you're thinking of looks really small.
For testing I got some sma connectors and external gsm antenna's with sma connector but the supplier I use also has surface mount antenna's made by Taoglas like these ones:
The thing which bothers me a little is the requirement for external components when using a smt antenna which has to do with matching the impedance.
hi
u can get a LEA-5S/5H u-belux
smart home assisted living
i'm doing project on meridian/p microcontroller and developing 24/7 observation system for emergency patient.the controller all ready connected with temperature sensor dis1624 and accelerometer lis302dl which are used for patient tempareture,body movement like fallen.with my microcontroller, i have to connect telit gsm 862 gps module to pass the data wirelessly with the location to the mobile straight.but i dont know how to connect them? i'm using microsoft .net micro framework(c# ).i'm really lost.can anyone help me please...please
Hello Stian, i'm also looking for small GSM module, and it seems the GE865 is the smallest available. I have one question, what GSM antenna are you using ?
Hi.
Thanks!
-Stian
You can use M10 from Quectel Wireless. It is really good GSM/GPRS module and only one module has GPRS Class12..
  • M10_GSM_Module_Specification_20090904.pdf
the elit GE865-QUAD use passive or active antenna ?
for gps module, we have M9129 which is only 13*15mm and cost effective, MT3329 chipset with -169dBm senstivity. plz check with this **broken link removed**
for small size gsm/gprs module, recommend you with QUECTEL M10 **broken link removed**
