Hi.
I am looking for a smal size GSM modem for smd mounting. Preferrably with integrated GPS module and good power specs. Though size is most important.
Anyone have any good suggestions.
I am currently using Telit GE865-QUAD. (22x22x3mm)
I do not have any suggestions and this antenna thing is new to me also as I previously used gsm modules which had sim card and antenna connectors on the module itself.
You seem to be serious about size The one you're thinking of looks really small.
For testing I got some sma connectors and external gsm antenna's with sma connector but the supplier I use also has surface mount antenna's made by Taoglas like these ones:
The thing which bothers me a little is the requirement for external components when using a smt antenna which has to do with matching the impedance.
i'm doing project on meridian/p microcontroller and developing 24/7 observation system for emergency patient.the controller all ready connected with temperature sensor dis1624 and accelerometer lis302dl which are used for patient tempareture,body movement like fallen.with my microcontroller, i have to connect telit gsm 862 gps module to pass the data wirelessly with the location to the mobile straight.but i dont know how to connect them? i'm using microsoft .net micro framework(c# ).i'm really lost.can anyone help me please...please
Hello Stian, i'm also looking for small GSM module, and it seems the GE865 is the smallest available. I have one question, what GSM antenna are you using ?
Hi.
for gps module, we have M9129 which is only 13*15mm and cost effective, MT3329 chipset with -169dBm senstivity. plz check with this **broken link removed**
for small size gsm/gprs module, recommend you with QUECTEL M10 **broken link removed**
