SMA jack surface mount or Through hole
glass
Newbie level 1
Newbie level 1
I'm designing a PCB which should support 2.4GHz radio signal with SMA jack, I'm not sure what better to choose SMA jack surface mount or Through hole.
surface mount: better signal behavior (no stub).
Through hole: connected better to the PCB.
I'm afraid the surface mount can not hold a coaxial cable load on it and after a while it will break.
Anyone ?
Some surface mount SMAs also have very fine mechanical connection properties.I recommend you to use high quality SMD SMA for 2.4GHz
Reactions: glass
    glass
