dhaab
end launch ghz
Hey everyone...
I am trying to get on and off a PCB at about 6GHz with the best S11 I can muster. I have been using a Johnson SMA end launch connector attaching directly to microstrip which has worked reasonably well below 3GHz. Above 4GHz this approach is probably not what I want to do. I have started looking at a CPWG structure at the initial launch point which transitions to plain microstrip but HFSS and CPWG do not seem to play well together. Specifically my port definitions are most likely incorrect.
So the question I ask is: A) Are there any suggestions for >4GHz SMA to PCB launch? B) Does anyone have an example HFSS file using CPWG?
Thanks,
Dan
Hey everyone...
Thanks,
Dan
