I am using a 2N3055 power transistor as a switch. With a simple 555 timer trigger with very clean square wave outputs, the power transistors output is sloppy to say the least. Is this typical?
I’m going to attempt to pulse high voltage DC (2k-20kvdc) and have written a PIC program which gives very clean square wave pulses from 150khz down to 2hz. My trigger signal is about 4-5vdc. Is there a better way to do this?
The images are examples of the 555 output and crude drawing of the 2n3055 output on an oscilloscope. Also attached should be the circuit used to test the power transistor.
