slew rate calculation
sujo.er
Newbie
I am doing my work inn cadence. Please give the steps to find slew rate using cadence virtuoso
i need to know the steps in cadence.. i know what is slew rate
there are some dscussions in this forum...Did you see the box below "similar threads"?
And there are a lot of documents on the cadence internet pages as well as from many other sources in the internet.
There are even video tutorials...
Please go through a couple of them to find out if it fits your needs.
Try to use one for your solution.
If you encounter any problems you should report this here...with a description (code) what you did, what results you expect, and what results you see. Also give a link to the dcoument you refer to.
