buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 954
- Helped
- 40
- Reputation
- 82
- Reaction score
- 21
- Trophy points
- 1,298
- Location
- Sunnyvale, California, USA
- Activity points
- 9,053
hi.
if i do a power-plane simlation with siwave, then the results look strange.
-in resonant mode analysis, the result amplitude is always between +/-1V. independently of any changes on the PCB. is it a normalised result? for example if there is a 1.8V plane, then what will be the maximum amplitude (at a given resonant mode, at the peak location on the PCB.)
-I want to know the AC impedance of the plane on a given point on the PCB. i specified a port (as an IC power input pin), so the "compute S, Y, Z param" results should show it, right? on the Z parameteer graph, it seems, the impedance is zero at zero frequency. as i know, it should be infinit. which graph shows the impedance versus frequency? the s-parameter plot: is it S12? S11?...
-in the nets view, there is only one net shown. i followed an siwave userguide, but there is nothing about specifying nets.
