[51] Single master multiple slave implentation using 8051 microcontroller
Help
Advanced Member level 2
I2C, Single master multiple slave implentation using 8051 microcontroller
Hello All,
I would like to use AT89C52 as a master to interface few AT89LP4052 (slave) with using I2C. This two MCU doesn't have build in I2C feature.
This few day i have do some research and can't find any useful information and sample code for 8051 I2C slave. But i do found this "Implementation of MCU Invariant I2C Slave Driver Using Bit Banging" for TI MSP430 controller. I'm not familiar with TI controller plus the sample code given is not complete. So it is difficult for me to modify the code and adapt to 8051.
Anyone can help me on this?
Thank you,.
Re: I2C, Single master multiple slave implentation using 8051 microcontroller
hello jayanth,
Thanks for your reply.
I have check the link. The sample tutorial given is for Master mode. How bout Slave mode?
You have to use external interrupt detection at slave side. Better use software SPI. It will be easy.
Ya, i have reserved the external interrupt pin at slave side. I would like to try I2C communicate among the MCU and the main board with C52 no reserve SPI port. :-(
From the article i found the code is really complicated but i think the code is able to fix in AT89LP4052 which is 4K ROM.
SPI is easy to implement and SPI code will fit in you micro but you need 1 pin extra for each slave for slave selection.
In software I2C slave has to monitor the SCL on every clock maybe with toggling the edge detect and data line is read on every rising edge of SCL. I have not done software I2C so I can't tell you much about it.
Ya i think SPI is easy to control but i need more pin SCL, MOSI, MISO, CE1, CE2, CE3,...and so on..Currently the main board just have SCL and SDA two pin to each board and my C52 have no many extra pin for SPI slave select have reserved for other other peripheral. :(
for spi you will need only one chip select pin if your slave is only one. chip select pins number increases as slave number increases.
and need only 4 pins SCL, MOSI, MISO, CS. and spi is faster then i2c.
