single/dual/multi-port SRAM
taoly
Junior Member level 3
Does anybody know what's the defference between single-port SRAM and dual-port SRAM, as well as multi-port SRAM? Is there any documents for SRAM design? thanks a lot.
see the following link regarding dual port ram
Al Farouk, there is no following link posted!
Also:
i don;t understand multi-port RAM in the sense that i have not encountered generators for anything else than single- and dual-port.
In my designs i often use multiple-output register banks which is different.
I would like if some vendor provided SRAM-based configurable register banks.
regs
the_penetrator©
Sorry for this mistake the link is
for me its also the first time to hear a bout multiport memory
signal port sram : has one address port;
two port sram: has two address ports;
multi port sram: has multiple address ports;
the ports mean how many path there are to access a ram array;
best regards
Two port SRAM: R/W data by 2 data bus which seperated control by 2 address, and reading or writing in 2 port simultaneously .
what prohibits reading and writing from/to the same location in memory at the same time ?
when r/w the same location, i think the logic is read the data come from write data bus not the RAM
Didn't get what you want to say ! ..
