aasimzee
Junior Member level 1
I am confused how to charge battery from solar panel and supply load at the same time. let me tell you my problem. I am using using 80w solar panel with the maximum current 5A approximately. I have charge controller which is supplying 12 volts to battery and load of 1A is connected across battery. My question is that if charge control is giving 5A ,will it divide like 4A ti battery and 1A to load or battery will behave as a short and whole current will go to load??
I have seen laptop charger it continiously charges and discharges.
Suggest a solution if i am doing anything wrong?
