but i don't have any "floating pin" in my circuit.Number of nodes with only one device attached (topology corrected): 25
Number of nodes with no DC path to ground (topology corrected): 8
Warning detected by hpeesofsim in topology check during circuit set up.
The following nodes have only one device attached to them (topology corrected):
D4.B1._net17
D4.L4._net46
D4._net292
D4.Q2._net40
_net548
D3.D6._net35
D3.S3._net59
D3.S3._net60
D3.D3._net46
D3.L5._net326
D3.L5._net327
D3.L5._net328
D3.L5._net322
D3.L5._net320
D3.L5._net318
D3.L5._net315
D3.L5._net312
D3.L5._net311
D3.M1._net44
_net540
B3._net17
D2._net22
G2._net35
B1._net17
D1._net46
The following nodes have no DC path to ground (topology corrected):
D3.L5._net326
D3.L5._net327
D3.L5._net328
D3.L5._net322
D3.L5._net320
D3.L5._net318
D3.L5._net312
D3.L5._net311
DBPSK_Mod4 _net552 _net554 RIn=50 Ohm ROut=50 Ohm RTemp=274 FCarrier=1000000 Hz SymbolTime=3.7037037 sec Power=0.01 W ExcessBw=0.5
DBPSK_Demod3 _net548 _net547 RIn=50 Ohm ROut=50 Ohm RTemp=274 RefFreq=100000 Hz SymbolTime=0.001 sec ExcessBw=0.5
OutSelector:O1 _net540 _net548 OutFreq=100000.0 Hz
BinaryCoder:B3 _net536 _net552 RIn=50 Ohm ROut=50 Ohm RTemp=274 SymbolTime=3.7037037 sec Type=0
Data2 _net536 ROut=50 Ohm RTemp=274 TStep=Tstep usec BitTime=SymbolTime usec UserPattern="" Type=1 SequencePattern=8 Repeat=1
GainRF:G2 _net527 _net518 RIn=50 Ohm ROut=50 Ohm RTemp=274 Gain=0.2+j*0.0 NoiseFigure=6 GCType=3 TOIout=dbmtow(37) dBc1out=dbmtow(27) PSat=1 W GCSat=1 GComp="0.0.0.0.0.0"
BinaryCoder:B1 _net547 _net517 RIn=50 Ohm ROut=50 Ohm RTemp=274 SymbolTime=3.7037037 sec Type=0
DelayRF1 _net536 _net515 RIn=50 Ohm ROut=50 Ohm RTemp=274 Delay=17.5 usec InterpolationMethod=0 IncludeCarrierPhaseShift=1
Yes, you don't have to worry about them at all.
This is not ADS Format Netlist.hello i am attaching the netlist.
.subckt SDC_AMFA_Cosim P1 P2
.param LOpower_dBm=7
.param LO_Freq=2.312GHz
.param RF_Freq=2.4GHz
.param RFpower_dBm='-50'
xDown_Converter P1 P2 _net12 SDC_AMFA Filt_Freq=88meg
RR3 _net12 _net4 50
.ends SDC_AMFA_Cosim
.subckt SUC_AMUFA_Cosim P1 P2
.param IF_Freq=88meg
.param IFpower_dBm='-50'
RR3 _net13 _net4 50
xUp_Converter P1 P2 _net13 SUC_AMUFA Filt_Freq=2400meg
.ends SUC_AMUFA_Cosim
Your previous netlist included ADS Format netlist.how can i find the ads netlist?
No.i found how to get the ads netlist
Not correct at all.you're right,
i believe this one is the correct one.
What on earth do you want to mean ?i made some other changes(replace the one converter)
and now i am getting errors for the Tstep and other time parameters which i had change also.
so i believe i must correct them.
i also used transient analysis in cosim blocks and not the envelope,
which is now deactivated.
Not correct at all.
Attached "netlist.cnex.txt" is a SPICE Format Netlist.
Surely read contents of link in my append.
Have your all problems been able to resolved ?
This is a SPICE Format Netlist.Tools>Netlist Export>Create ADS FrontEnd Netlist?
Your problems are very easy and trivial.i get the error message with the dublicate variable:LOpower_dBm.
when i used only the SDC_AMFA this error eliminated and i get errors about the timings like TStep.
Again surely read documents.
It is ADS Format Netlist.What makes you think that netlist_new.txt from post #13 is a SPICE netlist?
This command is for netlisting a SPICE Format Netlist.Tools>Netlist Export>Create ADS FrontEnd Netlist?
You can't understand a meaning of my append.
Of course, I looked file. So I can write following in "#14".No. I just wanted to tell you to read the questions and look at the file before posting answers what the file is.
You use "global parameter definition" in your schematics.
Do you understand this ?
What is your native language ?
It is very difficult and tired to read and understand your poor sentences.
Surely read documents.
Carefully check all schematics.
Agilent Ptolemy in ADS is not Digital simulator.but i am a new user in ads a not very familiar with simulations with analog and digital parts.
