8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
LIBRARY ieee;
LIBRARY std;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.numeric_std.ALL;
USE std.textio.ALL;
USE work.edge_package.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY camera IS
GENERIC( fi_n: STRING :="hexi.dat" ; -- Input hex file name
tclk: TIME:= 100ns -- Clock speed
END camera;
ARCHITECTURE behavior OF camera IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT dwt
PORT(
clk : IN STD_LOGIC;
vid_in : IN STD_LOGIC_VECTOR(7 downto 0);
hor_sync: IN STD_LOGIC;
vert_sync: IN STD_LOGIC;
val_flag : IN BIT;
vid_out : OUT STD_LOGIC_VECTOR(7 downto 0);
v_out: OUT STD_LOGIC;
h_out: OUT STD_LOGIC;
val_out: OUT STD_LOGIC
END COMPONENT;
COMPONENT moniter
PORT(
clk_i : IN STD_LOGIC;
vid : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
v_in : IN STD_LOGIC;
h_in: IN STD_LOGIC;
val_in: IN STD_LOGIC;
sts: OUT STD_LOGIC
END COMPONENT;
--Inputs
FILE image: TEXT OPEN read_mode IS fi_n;
SIGNAL clk : STD_LOGIC := '0';
SIGNAL vid_in : STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0');
SIGNAL hor_sync: STD_LOGIC:='0';
SIGNAL vert_sync: STD_LOGIC:='0';
SIGNAL val_flag : BIT := '0'; --Data Validation flag
SIGNAL vid_t: STD_LOGIC_VECTOR(7 DOWNTO 0):="00000000";
SIGNAL hor_t:STD_LOGIC:='0';
SIGNAL ver_t:STD_LOGIC:='0';
SIGNAL val_t:STD_LOGIC:='0';
SIGNAL finish:STD_LOGIC:='0';
--Outputs
SIGNAL vid_out: STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS=>'0');
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: dwt PORT MAP (
clk => clk,
vid_in => vid_in,
hor_sync=>hor_sync,
vert_sync=>vert_sync,
val_flag => val_flag,
vid_out => vid_t,
v_out=>ver_t,
h_out=>hor_t,
val_out=>val_t
--Instantiate display device
uut1: moniter PORT MAP(
clk_i => clk,
vid => vid_t,
v_in => ver_t,
h_in => hor_t,
val_in => val_t,
sts => finish
-- Stimulus process
stim_proc: PROCESS
VARIABLE chr: CHARACTER;
VARIABLE buf: LINE;
VARIABLE good: BOOLEAN:=FALSE;
VARIABLE vid_tmp: STD_LOGIC_VECTOR(7 DOWNTO 0);
VARIABLE tmp: STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
IF NOT(ENDFILE(IMAGE)) THEN
READLINE(image,buf); ---Read Hex image file to buffer
FOR i IN buf'RANGE LOOP
READ(buf,chr,good); ---Character read from the buffer
IF (good=FALSE) THEN
EXIT;
END IF;
IF(chr=',' ) THEN
val_flag<='0';
hor_sync<='1';
vert_sync<='0';
ELSIF(chr='*') THEN
val_flag<='0';
vert_sync<='1';
hor_sync<='0';
ELSE
hor_sync<='0';
vert_sync<='0';
val_flag<='1';
stdlogic_conv(chr,tmp); --Procedure to convert hexadecimal string to std_logic_vector
vid_tmp(7 DOWNTO 4):=tmp;
READ(buf,chr,good);
IF (good=TRUE) THEN
vid_tmp(3 DOWNTO 0):=tmp;
END IF;
END IF;
vid_in<=vid_tmp;
WAIT UNTIL RISING_EDGE(clk);
END LOOP;
ELSIF (vert_sync='1') THEN
--If the output file is written, abort the simulation
--IF(finish='1') THEN
-- ASSERT (FALSE) REPORT "Simulation failed!" SEVERITY FAILURE;
--END IF;
END IF ;
END PROCESS stim_proc;
ASSERT (finish/='1') REPORT "One Frame Completed!" SEVERITY WARNING;
clk <= NOT clk AFTER tclk; -- Clock generation
END ; |
