V
Member level 3
Hello friends,
in my behavioral code of state machine, its required to detect the input as low for N no if times. I am calling a task at that instance.
// Here I want to go to IDLE state after detecting low for N no of times
Receive_INPUT_LOW: // FSM STATE
begin:
if (input_line = 1'b0)
detect_low; //called task for detecting low
nxt_state <= IDLE;
task detect_low
begin
@(posedge clk)
for (i=0, i=NO_OF_TIMES_LOW, i++) begin
if (input_line)
break;
end
end
endtask
Now the question is FSM will go to IDLE after detecting low for N times? OR
directly after entering if loop (i.e. if (input_line = 1'b0)) ??
Your inputs are welcome, Kindly suggest. Thanks.
What I am saying about it.
- FSM will directly go to IDLE state after detecting if loop, But that is not my intention here.
So what to do? I have to change the code like this
task detect_low // Modified task
begin
@(posedge clk)
if (input_line)
break;
else
signal_a = 1'b1;
end
if (signal_a)
signal_b = 1'b1;
end
endtask
Receive_INPUT_LOW: // Modified FSM STATE
begin:
if (signal_b)
nxt_state <= IDLE;
Is it correct? Is this method is correct? pls share your inputs/comments
Thank you..
begin:
nxt_state <= IDLE;
task detect_low
begin
@(posedge clk)
if (input_line)
break;
end
end
endtask
begin
@(posedge clk)
if (input_line)
break;
else
signal_a = 1'b1;
end
if (signal_a)
signal_b = 1'b1;
end
endtask
begin:
if (signal_b)
nxt_state <= IDLE;
Thank you..
