I want know the different steps that I must fellow to simulate ( the monostatic radar cross section ( RCS) ) of 3D objects ( box , cylindre,...) with HFSS v9.0:
I have not found an example or project of simulation of monostatic RCS by HFSS 9.0? or a documentation (*.pdf )
if you have an example, project or documentation about simulation monostatic RCS with HFSS 9.0, please send it to me.
The Vector Fields CONCERTO (CLASP) helps in analysing Mono-static & Bi-static RCS...
Go through the attached PDF document on an example & descrtiption on RCS simulation...
Hi, I've been looking at this problem for a while too. The closest solution to the problem is that for bistatic scattering application which follows a similar principle.
You can find it as part of a field calculator tutorial here
**broken link removed**. If you have HFSS 11, floquet ports make it easier to solve this particular example using linked boundaries.
