Simulating Pozar's BPF in MWO
vistadude
Newbie level 5
South Africa
pozar chapter 1
I recreated the low pass and band pass filters from chapter 8 in Pozar's Microwave Engineering (second edition) in Microwave Office ( v8 ). The simulation results for the low pass filter is the same as in Pozar, but I can't get the BPF to simulate correctly. Any Ideas on what I'm doing wrong?
vfone
Advanced Member level 5
filter pozar
I don't know what you did wrong, but I've checked the circuit and everything is fine.
Manjunatha_hv
Advanced Member level 3
INDIA
Hello,
Yes, you should be able to get any lumped elemnt filters response exactly in AWR Microwave Office (MWO)...
Even it provides good results for Microstrip /stripline filter, see the following pdf
---manju
vistadude
Newbie level 5
South Africa
A post-grad pointed out my mistake - I used models that included Q. Replacing them with the simpler models fixed the simulation.
Thank you for the replies.
Manjunatha_hv: The PDF you linked to gives me a "Connection refused".
