Simulating IP Core on Modelsimsim SE
dinesh.4126
Member level 5
simulating ipcore
I am Trying to simulate ROM IP core on ISE10,1 using MODELSIM SE 6.1b.For simulation of IP core on modelsim will I neede to download xilinxcorelib.zip and simulation_libraries as per stated in link: **broken link removed** I am simulating without xilinxcorelib.zip and simulation_libraries its shows failed to access the xilinxcorelib..But once I copied both library in modeltech and using dos shell type compxlib -s mti_se -f all -l all -w -o . then on shell its show cae interfaces :374 incomplete argument specified.
Basically I have download the xilinxcore.zip for ISE8.2 will it make any difference if I am using ISE10.1.
Can somebody suggest me upon this????
I really stuck up at this how to simulate IP core.
Kindly Assist me.
xilinxcorelib modelsim se 6.1
Your compxlib option "-o" is not valid. Type compxlib -h for all available options.
You do not need to download the files, they are supplied already with version 10.1. You only need to compile them with your simulator. I recommend to use the files for version 10.1 (and not to use 8.2) as the sources changes due to new IP cores.
Devas
