pci32tlite
hi.
how to simulate a PCI target interface core?
i was trying to do that: set command reg, set BAR1 reg, the target generates a response, but if i want to read back a register (BAR1) then it reads zero.(config read) if i want to make a memory read (based on BAR1), then it doesnt response, at any addresses.
the ise8.1 project:
http://buenos.cjb.hu/download/Copyof10.part01.rar
http://buenos.cjb.hu/download/Copyof10.part02.rar
Simulete a post ranslate, because i used ngc blackboxes, and its not possible to simulate just a behavioral model.
this is a PCI to whisbone bridge, a Whisbone intcon and a CAN and GPIO controller.
On the target board (not simulation), if i do memory read, the values are 00 always in the image1 which is the internal memory. in the image0 which is the config space-copy, i can read correct values. I use a a whisbone INJTERCON from the altium designer. If I use the intcon from the opencores.org, then it (the windows) freezes during read.
in simulation, i cant even set the and read the config registers (using config read/write)
