I'm trying to simulate an antenna array together with switches in CST, and meet with two problems:
1. I'm not sure about the procedure. My solution is: add the S-parameter document of the switch into touchstone in schematic view, connect the corresponding ports, add a new task 'block', choose high frequency and Frequency domain, then click 'update'. Is this the right way?
2. It takes long time to update, it stays at the 8th pass of adaptive mesh refinement, and I believe there will be more. How I can solve this problem?
Thank you.
