^saint^
Newbie level 6
- Joined
- Jun 26, 2010
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,404
Hello
my current project uses a sensor that that produces a sine wave (DC...~5kHz) with varying amplitude (max Vp-p ~60mW). Noise from the sensor is about 3mV max. and output offset voltage is -0.2V to +0.2V
Current schematic:
What is the purpose of C10?
In the schematic the U1 has a fixed gain and U2 uses a pot to adjust the gain. What I would like to do is use a simple AGC (probably FET as VCR) and vary gain of U1 (x10-100) 20-40dB and keep U2 gain at 40dB.
The output signal from U2 is then converted to a square wave (simple comparator with histeresis, High Threshold: 3.2V, Low Threshold:2.8V, wave is centered at VCC/2) to count the frequancy of the wave so I only need to avoid distorting the frequency.
Been reading up on FET based VCR for AGC, I'm particularly interested in simple circuits like AN-32 FET Circuit Applications (2N3685 on page 6) or this one VARIABLE GAIN OP-AMP CIRCUIT. The problem is that most of them don't give any values or specify the FET (N-channel JFET, right?) plus FETs characteristics are inconsistent from device to device.
This topic JFET as variable resistor was quite helpful but didn't clarify all.
Hopefully someone can point in the right direction for choosing a particular FET. Most of the datasheets only specify Rds(on) and don't mention Rds(off)?
Or is there a simpler way to implement AGC for an op amp?
Current schematic:
