eduardoarnoldh
Newbie level 2
I am trying to implement **broken link removed** design of a simple RF transmitter.
I have successfully mounted the oscillator and was able to make it work with low frequency drift on the FM range. I have only changed the transistor to an 2N3904, and adjusted the bias resistors, since that ZTX is not available anymore AFAIK.
I also mounted the audio pre-amp and when tested without energizing the oscillator, by using the probe on the buffer output, it worked fine.
The problem resides in energizing the oscillator, checking the buffer output, even removing the connection from the buffer to the transistor, there is a lot of oscillator signal interference, the audio signal is completely lost. I have tried increasing the cap C5 to try and reduce high-frequency interference (as it is the case), but it did not produce significant change, still the audio signal unrecognizable among the interference.
As far as I understand this is the reason why I can't hear anything but noise when I tune my FM radio on the frequency of oscillation. To ensure that the basic design was working I tried using a signal source to produce a sinusoidal signal and couple it through cap C6. I could hear, although with some noise, the sinusoidal wave on the receiver. So I guess the problem is the interference on the amplifier that shades any audio signal I have on the mic.
It makes me wonder how the circuit from that schematic would work with this kind of interference. Does anyone have a suggestion on how to proceed in this case?
Thanks in advance,
Eduardo.
Thanks in advance,
Eduardo.
