If you intend to build a 9V PS, I'd suggest Transformer + Rectifier + Smoothing + 9V Regulator, see:I am using a normál 9v dc battery.
No , a simple linear regulator for RF systems isn't good .
My power transmitters have been around 60W in the 30MHz to 200MHz range. No problems with linear power supplies. I agree they are important but I don't see anything inherently wrong with a linear supply with RF systems, either transmitter or receiver.
Keith.
Dear zeller
Again Hi
If the impedance of your antenna is about 50 ohms , thus the maximum power across it will be about 180mw .
so do you want to supply it from main power line ? if yes , i'll send you a good and simple circuit.
Good luck
Goldsmith
Dear zeller
Again Hi
Good luck
Goldsmith
