Simple PLL FSK Modulator needed
ClaudioCapellini
Cordoba Argentina
pll fsk
Hi all:
I need a simple circuit to make an FSK modulator (with F0 = 400 kHz) with a lausy PLL like LM566 (from N@tional). The receiver is working great with LM 567: with any signal it demodulates, with noise, it demodulates even better, I yel to the board and demodulates too!
But I'm still looking for a good Modulator. Bandwith = The most I can get (like allways happens) but 20kHz will be great.
thanks to all in advance!!!!
flatulent
Advanced Member level 5
Middle Earth
simple pll
Exar makes FSK ICs. One is the XR205. They are based on the VCO in the PLL ICs.
Alternately, force a two level DC voltage onto the loop filter pin of the PLL IC you are going to use for tone generation. First put in the two tones you want to generate and measure the loop filter pin voltage at each of the two frequencies. Use these. The data sheet shows that two resistors and a current source are connected to this pin so you probably will not break anything by trying the above method.
Stark
Member level 2
565 fsk
try to see cypressmicro application note you can find good solution with pSoc devices
www.cypressmicro.com
Stark
shahrol_hisham
malaysia
simple fsk modulator
I also want to know how to design fsk receiver
dsjomo
Full Member level 2
Taiwan
ne564 pll modulator
If you want to demodulate FSK signal, a PLL can do the job by observing the input voltage of VCO.
IanP
West Coast
simple fsk modulator design
Other option is to use the NE564 PLL as FSK modulator ...
Example here:
varunkrish
Newbie level 5
fsk pll ic
i also need a simple fsk demodulator using lm 565
