Hi.
I have some lm741 opamps, and I've been trying to use them.
I created a +vcc -vcc supply using two 9v batteries with the gnd as the point in which one batt's + is connected to the other's - .
I tried to create the basic configurations: first - open loop, ie vee to the -9, vcc to +9, and the input to the gnd or +vcc (for trials...). I expected the output to yield 9v but nothing was outputted (I connect to the output a simple motor which runs on less than 9v, but it didn't spin). I expected the motor to run when the input is connected to +vcc and to stop when the input is connected to gnd. But - nothing happens at all...
I also tried a simple negative feedback with both inverting and non-inverting, using several resistors (to create some different gains). And nothing on the output.
When I tried to connect the voltage inputs (vee,vcc) the other way (ie +9 to vee, -9 to vcc) I just got the motor to work but the opamp got real hot real fast so I disconnected.
Is there something I'm missing? some other wire perhaps I should be connecting? It should be really simple... I tried it on some 3 opamps I got and on all I get the same result.
Thanks.
