SIM900 Customer Flash Loader
Yes, you are correct. The standard firmware does not support DTMF detection or MMS commands, so you need to upload a version that does. It is posted above
I just want to make sure I am getting this straight. I have an EVB and SIM900 modems. The Firmware that is pre-loaded is Revision:1137B11SIM900M64_ST.....Am I understanding correctly, that in order to access the MMS AT commands....I have to change the firmware? It currently spits out errors when I try to use any of the MMS commands.
Thanks in advance,
Amie
1575B10SIM5215A.rar (16.35 MB)
SIM5320_SERVERSTART_ALREADY_LISTENGIN_KPRBL_2.rar (7.09 MB)
attached
  • 1575B10SIM5215A.rar
  • SIM5320_SERVERSTART_ALREADY_LISTENGIN_KPRBL_2.rar
hi chipseller
i am facing a very strange problem with sim900, when connected to gprs and a sms is received it crashes and restarts. if this happen three times then sim900 goes into a state where it does not respond to pwr key and at commands, after crash netlight starts to blink as if there was no sim card present. i have to manually disconnect sim900 supply and reconnect it to make it work again.
this issue is very frustrating as while connected to gprs service provider may send sms advertisement and sim900 will crash and restart.
i have two modules:
SIMCOM_Ltd
SIMCOM_SIM900
Revision:1137B10SIM900M64_ST
SIMCOM_Ltd
SIMCOM_SIM900
Revision:1137B08SIM900M64_ST
both of them have the same issue, any advice is highly appreciated
thanks
Try updating the firmware. This may have been a known issue, I don't know. I have attached the latest version and release notes. All the tools and instructions are available in this thread
  • 1137B11SIM900M64_ST.rar
  • NDA_SIM900M64_ST Firmware Release Note.pdf
hi chipseller
i updated the module with the firmware you sent but still the problem exists, i also tried with this command: AT+SRSPT=1 but no success
can anyone having evb board confirm this issue, i feel this problem is because of sim900 firmware and not because of any fault in hardware design.
please if anyone having evb board confirm this:
1. connect module to gprs
2. and then send sms to module while connected to gprs
3. confirm if its crashing and resetting or not.
thanks
also is there a way to completely reject/disable sms feature?
Hi chipseller!
Do you have access to sim900d firmware with DTMF? Like 1137B08SIM900D64_ST_DTMF_JD_MMS or B09. And could you share it plz?
Thaks in advance
Hi All the frmware I have access to is already shared in this post. The 1137B08SIM900D64_ST_DTMF_JD_MMS is the only version I have and it is already posted here.
Hi chipseller!
Thaks in advance
Sorry, but I don't found it. Only 1137B08SIM900M64_ST_DTMF_JD_MMS from post #58 for sim900, but I need 1137B08SIM900D64_ST_DTMF_JD_MMS for sim900d.
hi...anybody have mms firmware for 1137B08sim900A32_ST ?
As far as I know this firmware will work in the D and is the only one I have access to.
Sorry
Hi chipseller
Will the 1137B08SIM900M64_ST_DTMF_JD_MMS firmware update work on SIM900B?
I have successfully downloaded this update to my SIM900B but the module doesn't register to the network nor does it respond on hyper terminal.
Earlier i have tester the module it had 1137B08SIM900B32_ST firmware in it.
Thanks.
Hi marc_m
It sounds like it probably doesnt. Reload the original software to restore the module. Here is the latest version I can get.
Hi chipseller
Thanks.
  • 1137B09SIM900B32_ST.rar
  • NDA_SIM900B32_ST Firmware Release Note.pdf
Hi chipseller,
thanks for the updated firmware.
Hi chipseller,
Hi guyz,
I have a sim900A GSM module! but it makes me crazy during updating the firmware!
for the first time, when i tried to update the firmware, i saw message 'Erasing flash, please wait' but after a while program alarmed timed out!
also before it netlight and status led were on!
now when i press power key down to start updating, when i hold it down for a while, i got this error:
when update starts and during filling progress bar i leave the button i got this error:
so what should i to do?
best regards
The same thing happened to me, my unit is completely unresponsive now, is it bricked?
Dear friends,
SIM900 is so problematic and so, I cancelled a project and send an email to
firm and there was no response up to now as expected.
My email is given below:
Dear Sir/Madam;
Unfortunately, we are throw away our project that used SIM900 Modem
due to defected products.
Are your modems tested before release to delivery worldwide ?
Are your modems have detailed and also simplified (plug & play minimal needs) application data ?
Why we are having trouble to download test software, firmware updater, firmware files and application files ?
I decide to write this email to get a response to show how big are you.
Sim900A is made for eastern asia!
so it just supports operators is easter asia!
One of my friends, set a mail to Sim company and they replied it!
china
india
singapor
malaysia
thailand
indonesia
cambodia
vietnam
laos
burma
brunei
philippines
east timor
when we upgrade it, we set our MCC code into sim900A, so we can use it... (I read it in some non-english forums!)
anyway, I could not upgrade it successfuly! so I decided to use Sim900
it works fine... also I used Sim908
Hi chipseller,
New Firmware Releases in SIM900D or SIM900
These are the latest I have access to, some ar aleady posted. Check your current version is compatible before downloading a new version
  • 1137B04SIM900M64_ST_MMS.rar
  • 1137B09SIM900D64_ST_DTMF_JD_MMS.rar
  • 1137B10SIM900D64_ST.rar
  • NDA_SIM900D64_ST Firmware Release Note.pdf
